7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | I have discovered that my 51 Chevy 1/2 ton has a "modified" front grill. It appears the previous owner has replaced a couple of the horizontal bars. For some reason the assembly appears strangely un even. I am aware that the top/bottom/and parking light bars are each uniquely different but are the number 3 and 4 bars (from the top) the same? Is there a difference in the length of these bars? Can they be interchanged? Thanks
Best Regards Will
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | All 5 bars are unique and progressively longer from top to bottom. Interchanging 3 and 4 would give you what you're probably looking at or maybe you have 2 #4 bars. Look around and you'll find decent individual ones. They should all overlap the end vertical pc's by the same amount.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
