1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12218 04/26/2005 2:22 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | Is there an easy way to tell if I have hyd or solid lifters before I try to adjust them? I think the motor is a 235 blue valve cover -- number on shelf next to distributor 002097554Y on head pass side B-24 018 241 570 on manifold exh. GM 28 883587- on intake 3764644- on head carb side 3886848 motor is in a 1940 chevy. thanks Bill | | |
#12219 04/26/2005 3:35 AM | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Clamp a pair of vise grips on a rocker arm with the valve fully closed, and give it a firm pull toward the adjuster, not the valve, for about 5 minutes. If the clearance gradually increases until it's about 1/8", you've got hydraulic lifters. Don't worry about the excessive clearance, the lifter wil pump up again as soon as the engine is started. Jerry
#12220 04/26/2005 7:52 AM | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | By the serial number and head casting number and casting date, it looks like this engine is a '54 235. In addition, the "Y" serial number suffix is for the powerglide-equipped car engine, which originally came with hydraulic lifters, so chances are good (if not 100%) that the lifters are hydraulic. Is there any lash with the engine running?
Edit: Could the head casting number really be 8386848? Also, could there be an F or T in the engine serial number, as in "F54Y" or "T54Y"? I made these assumptions in my assessment above. Also, the intake number might match a '59-'62 intake. Could the exhaust manifold number be 3835587? That would be for a '50-'62 235/261 exhaust manifold.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
#12221 04/27/2005 1:29 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | Thanks for the information nice to know when after parts. I took off side cover has hyd. lifters. what is the best way to addjust motor stoped or running? | | |
