1 members (baldeagle),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | My engine temp gauge is not working and while trouble shooting, I can find no mention of an electrical temp sensor, but my system is. I have a sending unit at the back of the engine in the block (235) with an electrical connection that runs into a wire harness at the firewall. At the back of the panel, 2 wires exit the same harness ( I guess one from the sensor, and one from the ignition switch?) that connect into the back of the temp gauge. All the literature I can find only talks about a tube that connects from the engine to the gauge to indicate temperature. Anybody with any information on this setup? Thanks, Lee.
1956 Chevy 3200, 235 w/3 speed
| | | | | Joined: Dec 2016 Posts: 80 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 80 | If I'm correct here, you should have a red/pink wire to the gauge and a green going to the sending unit on the top of the head. The only "tube" would be for the oil pressure gauge. That is how my 59 is set up and I actually have the IP pulled away from the dash as we speak. Hope this helps, let us know!
1959 3204 Basic Cab
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Lee, you're likely looking at the 55 shop manual - the 55.2 and some early 56's had mechanical temp gauges .... see the 56 manual supplement, which has a more applicable wiring diagram Bill | | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | Thank you both; I was looking at the 55 shop manual, and the 56 truck wiring diagram. I have the supplement for the 56 truck manual, but neglected to look in it. I'll pencil in the additional wiring on mine. I hope to start a rewire in the next couple of months so it is good getting this info now. Thanks again.
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Are you sure the guage isn't the culprit malfunctioning?
1959 3100 Apache Fleetside
| | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | Could be the gauge, I have not done any real troubleshooting other than switching the terminals on the back of the gauge. I'll next check if I am getting power and if I have continuity from the sending unit. If that all checks out, then it will be either the gauge or the sending unit.
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | If you switch the wires on the terminals it could very well finish off the gauge. That would essentially connect 12 volt power to the sending unit side of the gauge which is usually not good. Also, be wary of aftermarket sending units, some work, many do not. Fred
