0 members (), 144 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
I saw a you tube video where a guy to start his 6volt Packard using a 12volt jump box to start the car. Will this harm anything?
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
WELL...... A 6v chevy starter loves a 12v system.... According to Patricks.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
Ron, it's done all the time. Jump starting a 6 volt with a 12 volt. Just don't leave the 12 volt hooked up more the a few seconds. It might go boom!💥 The 6 volt battery that is. The starter doesn't care but the battery does.
I tried to find the youtube video. He did some rewiring and bypass of some wiring because he kept it wired all the time for cold starts. Thanks.
2017 Buick Encore
See more pix
I like to compare electrical voltage to water pressure. Most electrical devices are made to handle 20% above or below spec. A 6 volt starter will take the added pressure of a 12 volt battery, just don't crank it for a extended period of time! If you keep doing it, eventually it will not survive the added voltage.
1959 3204 Basic Cab
Think most here will say With 12 v applied the current flow ( amps) will be half that of the 6 volt .........so the starter will be just fine if not better off with 12 volts.
Did somebody repeal Ohm's law?
[/quote]
Yes........ I was thinking volt x amp = watts.........not thinking the motor winding resistance did not change...........but the starter will still be happy at 12 volts.
If your engine doesn't start right away with a 6 volt battery fed by a 12 volt battery, you have another issue which needs attention. That starter turns the engine over extremely fast.
