| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 38 | Will this work? I have a 1959 chevy apache 1/2 ton. need engibe rebuilt, but found a nice 194 locally. Just want to make sure it can be done. Any and all advice/suggestions are welcome. Thanks. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Assuming you're talking about the modern 194, you'll be losing 41 cubic inches and a lot of torque due to the shorter stroke. You can use a bellhousing for a 59 V8 to adapt the rear mounting points, but you'll have to fabricate new front engine mounts. The exhaust, and probably the radiator hoses will have to be adapted as well. It's not a bolt-in swap by any means. A 250 will require the same work, but you would get a little horsepower gain, and little if any loss of torque. Jerry
| | | | | Joined: Jan 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 38 | Thank upi both for the feedback | | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | You will also have to lower the radiator, the water pump on the 194-230-250 engines sets much lower on the engine. This makes the cooling fan hang below the lower tank. | | |
