0 members (), 106 guests, and 0 robots.
Topics128,101
Posts1,056,181
Members48,436
#1221528 06/15/2017 10:18 PM
Will this work? I have a 1959 chevy apache 1/2 ton. need engibe rebuilt, but found a nice 194 locally. Just want to make sure it can be done. Any and all advice/suggestions are welcome. Thanks.
What year 194?
1929-1932?
Assuming you're talking about the modern 194, you'll be losing 41 cubic inches and a lot of torque due to the shorter stroke. You can use a bellhousing for a 59 V8 to adapt the rear mounting points, but you'll have to fabricate new front engine mounts. The exhaust, and probably the radiator hoses will have to be adapted as well. It's not a bolt-in swap by any means. A 250 will require the same work, but you would get a little horsepower gain, and little if any loss of torque.
Thank upi both for the feedback
You will also have to lower the radiator, the water pump on the 194-230-250 engines sets much lower on the engine. This makes the cooling fan hang below the lower tank.
