3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
Anyone have an idea of what the torque specs are on the fly wheel and the pressure plate bolts?
Engine: '40 216ci.
I'm ready to mount the engine this weekend...
Oh happy day!!!
Thanks in advance.
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
From the 1948-51 Shop Manual reprint- 50-65 ft.lb. Yours is probably the same.
If the flywheel-to-cranklshaft bolts are 7/16" fine thread, like I suspect they are, the 50-65 specification should be right on. The clutch cover bolts are probably 3/8", and should work OK with a maximum of 35 ft/lbs. Don't try the higher torque on the pressure plate!
Thanks Guys!
Regards, Kevin
