| | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12214 05/27/2005 11:13 PM | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | Anyone have an idea of what the torque specs are on the fly wheel and the pressure plate bolts? Engine: '40 216ci. I'm ready to mount the engine this weekend... Oh happy day!!!
Thanks in advance. | | |
#12215 05/28/2005 3:09 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | From the 1948-51 Shop Manual reprint- 50-65 ft.lb. Yours is probably the same. | | |
#12216 05/28/2005 4:41 AM | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | If the flywheel-to-cranklshaft bolts are 7/16" fine thread, like I suspect they are, the 50-65 specification should be right on. The clutch cover bolts are probably 3/8", and should work OK with a maximum of 35 ft/lbs. Don't try the higher torque on the pressure plate! Jerry
#12217 05/28/2005 6:07 AM | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | | | |
