7 members (GMCJammer51, NJC, Southerntruck, Gdads51, 3B, 55shaker, 1 invisible), 117 guests, and 3 robots.
Topics128,091
Posts1,056,392
Members48,442
Hi All,
So I haven't had much luck finding a 7.5' bed, at least one in decent condition for my '48 3600. I do like the thought of an all-wood bed, similar to the 'GMC Huckster' and I do have fenders that are passable for now. What I'm looking for now though, would be the Outside Dimensions of a regular 7.5' bed. Specifically the dimension between the rear fenders, where they bolt to the bedsides. I've never had a bed or fenders for that matter on this truck, so nothing to go by.
Also, what would a suitable lumber dimension be to scribe out the wheel 'hump' in the frame, but leave enough strength in the support and also not raise the floor height too much!
Thanks in advanced!
P.S. Yes, I have already received some great details from Rob, the owner of the GMC Huckster!
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
Per the info from the GM heritage site, the 7.5' bed is the same width as the shorter bed, 50 inches inside measurement. Add to that the thickness of the metal, 1/16" per side and the dimension between the fenders would be 50-1/8". Probably not enough to make a difference if you just went with 50 inches.
Thanks Kevin, I didn't realize the bedsides were that thin.
The bed length is 87" on the inside, I guess anything around there would be pretty close.
Maybe the wood beam size for scribing over the frame hump is a good question for someone who has built a flatbed?
Thanks!
More images
No takers yet, maybe a different thread?
More images
So, I'm ready to start with the bed build, mostly because I need to mount the fenders to get it road worthy. One question I do have is what is the spacing between the back of the cab and the bed? I know my 3600 should have an 87" bed, but I'm curious as to where to start and end it. Thanks!
More images
No takers on that one... I left around 5/8"-3/4" if anyone is interested. I've also scribed my lumber over the axle hump, here's a pic:
https://goo.gl/photos/wfxEyC7z46JYLnePA
On the passenger side, the fuel filler neck for the 'under-bed' tank sits about an inch or so off the frame. I was trying to decide if I should cut a nice round hole to slip it through, or if I should do a inverted "U" down to the frame. The round hole would look the best, but I'm thinking that if I need to pull the bed off for any reason, a "U" would allow it to lift straight up.
Any thoughts/suggestions?
More images
