2 members (Gdads51, Flint48), 165 guests, and 2 robots.
Topics128,088
Posts1,055,995
Members48,430
Its been over 5 years since my restoration started, now things are going back and I am at the stage of securing the hood. I have the 4 bolts for the hinge that have a machined shoulder to allow for pivoting. I can't find what I removed for the spring, is it similar or will a regular bolt do, any help would be appreciated before I make any attempts. With a little help from my friends we lifted the hood into position and now for the next step.
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
If I remember correctly the bolt going into the hood also has a shoulder on it and the other two that screw into the firewall are standard bolts.
I second what Alvin said. I was just messing with front clip adjustment on mine. Upper spring support bolts are shouldered.
Thanks for the confirmation, my suspicions were correct, will have to do a thorough search again even though I labelled everything they might have been misplaced
Just before leaving to buy a kit from a local vintage truck parts supplier I took one last look, in a box of misc bolts I found the two shouldered bolts for the springs, I couldn't believe it and saved myself a few bucks, maybe go out for lunch to celebrate
They are always in the last place you look!
