| | | Forums66 Topics128,050 Posts1,055,753 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2016 Posts: 80 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 80 | Wondering what the factory colors were for the starter and generator on my 235. Painting the engine back to the original grey after repairing various leaks and now would be a great time to clean them up and paint them. Pretty sure the generator would be black, not sure of the pulley and bracket. Totally lost as far as what color the starter was. This engine was a combination of the original grey, chevy blue and partially black!
1959 3204 Basic Cab
| | | | | Joined: Dec 2016 Posts: 80 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 80 | Generator bracket that mounts to the engine? Pulley black or same as the end plates? Thanks for the great information!
1959 3204 Basic Cab
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Sorry, deleted to rewrite. The factory photos I find and the NOS parts I find, show black generator case with aluminum color end plates and black pulley/fan blades and brackets. Starter shows all black except nose is unpainted. Some have "aluminum" colored end plate also. Many end plates are aluminum. When I have a question about "factory" correct, I go to Ebay and search factory sales brochures for sale, for the year/model in question. Many are black and white. None have actual photos and some are "artist deceptions". But they do pay off sometimes.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | generator case and fan pulley Delco Semi-gloss black....Aluminum end plates natural aluminum. Starter Delco semi gloss black on case, drive end housing and end plate. by 1958 they were several years into the stamped steel end plate with brushes made into the case but I have seen a few with an odd looking aluminum plate but not often. If you do have that aluminum plate it would be natural, steel End plate was black. Ken
