4 members (Hotrod Lincoln, Gray_Ghost, cmayna, dt235sd), 119 guests, and 0 robots.
Topics128,051
Posts1,055,732
#122111 09/22/2006 9:27 PM
Junior Member
Junior Member
Heres my idea... Since I've removed my stock tank on my '59, I need to fill the hole where the filler used to be...I don't have ready access to a welder so my idea is as follows
: Take a piece of stock gauge metal and cut it to size just about 1/4 inch wider than the opening and use JB Weld to bond it to the inside of the opening(inside the cab). Once cured, Go over the outside with the appropiate filler to smooth everything out. Is it crazy or not too bad of a budget idea??? Thx for the comments, J
#122112 09/22/2006 10:48 PM
I saw that being done on the show "TRUCKS" a few weeks ago. But they used something else other than JB weld. You should be able to check out there website for more info.
For me I'll stick with my welder. Good luck
#122113 09/22/2006 11:02 PM
I think they make a panel adhesive just for that. Check your local auto paint supply store.
#122114 09/23/2006 5:18 AM
Junior Member
Junior Member
that will work just be sure to rough things up with some 40 grit first. I fixed the water jacket in a jap moter & put 50k miles on it.
#122115 09/23/2006 4:28 PM
Junior Member
Junior Member
I appreciate the info Ya'll...
#122116 09/24/2006 5:32 AM
Howdy, I think they are using a product called FUSOR. I was kind of thinking of using it along with a few spot wields. I have a good friend that is restoring a 64 Impala and he is using if for most all of his metal panel repairs.
Here is a link for the stuff.
http://www.refinishmaterials.com/ct_CGmetaladhesives.htm
I hope that helps… Good luck!
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
#122117 09/24/2006 5:57 AM
i did that on a 67 Camaro Dash some chuckle head drilled a bunch of holes in... I duct taped the back of the dash, and filled it in with the jb weld... then i sold the car.
Another quality post.
Real Trucks Rattle
#122118 09/27/2006 12:32 AM
i'm with rusty rod! always start ANY project with duct tape. the more the merrier! and don't forget bailing wire grin
#122119 09/27/2006 3:28 PM
If you go to an auto paint store you can buy "structual panel adhesive" and do your patch the right way with proven automotive products. Yes you can "glue" these panels in, is done every day in the manufacturing and repair of automobiles.
BMW even has a repair bulletin for the 2004-06 5-Series where you glue the frame rail in! No welding what so ever, only glue!
Here is a bulletin from GM on gluing in a patch panel.
http://members.aol.com/whatcouldiknow/gluepatchpanel.jpg
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
