1 members (KEVINSKI),
124
Mod | | | Forums66 Topics128,130 Posts1,056,706 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Howdy Folks,
I have alot of bare metal on my truck right now. I sandblasted it clean so I could cut out all the rust and replace it with new tin.
The bad news is that I am forced to move my project out onto the driveway for a month. My garage concrete pad is being replaced.
So, I need to prepare my truck for survival outside.
Does anyone know a good way to proceed in this situation?
Thanks!
Zeke | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I think you've got to get some etching primer on the bare metal, and then something ontop of that- primer or sandable sealer. I think sandable sealer would be best because primer doesn't keep out water too well.
| | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | I totaly agree with NM51 but use an epoxy primer it is alot harder and will resist water alot better. | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | Epoxy primer is the only primer that will withstand the weather as it is a sealer too and won't allow the water throught.
34 & 35 trucks are the greatest
| | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Hey Guys!
I'll head over to the local autobody supply store and see what they can do for me.
Thanks!!
Zeke | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Maybe you can find a 'self-etching expoxy primer' instead of using etching primer first and then expoxy primer.
Good luck!
| | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | To use the epoxy primer after sandblasting you only have to use a good grease and wax remover; then paint.
| | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Yeah, that's exactly what I learned yesterday at the autobody supply store.
I got the epoxy primer, the wax and grease cleaner and the thinner for clean up.
Thanks guys! | | |
