7 members (49nut, moparguy, ndkid275, Barry Martak, tclederman, kades51, 1 invisible),
78
Mod | | | Forums66 Topics128,133 Posts1,056,396 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 93 Shop Shark | | Shop Shark Joined: Apr 2017 Posts: 93 | I've been reading about installing a headliner (seems pretty difficult) and there is always mention of slipping the headliner under the front glass gasket. If I'm planning on replacing the glass this summer, should I do that before putting in the headliner? Thanks in advance for any info or advice.
*for a 1950 coe 2 ton | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I haven't yet fitted a headliner to mine (a '50 3100) but was always under the impression it was secured/held at the front by the inner garnish mouldings,I wasn't aware the rubber actually overlapped it? If it does,that's news to me. I always thought the biggest issue was the door windlace rubbers which I believe DO overlap.
Someone will chime in soon with a definitive answer,hang tight!
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Second Jockbolter50 The windshield rubber has no effect on the headliner. | | | | | Joined: Dec 2006 Posts: 3 New Guy | | New Guy Joined: Dec 2006 Posts: 3 | I have a 54 3100 and just installed a new headliner. On the 54 new flexible windshield and cab windlace rubber is extremly important in installing headliner. My windshield and cab windlace in brand new. Was able to install the headliner under both but it was a pain. The windlace rubber flexibilty is way more important and i would think it easier to install headline first. Not mentioned anywhere is the trick i found by accident. Use the metal center headliner bow as a guide to trim the cardboard edges to correct side to side length. Yes, you do need to trim it and its a hairy scary one try deal. Even more important is to wait till AFTER the headliner is completely installed to cut the holes for the Passenger side visor. Go slow. Use the supplied pattern to find the approximate hole locations with a small sharp awl and the visor bracket to get correct locations.. Another one shot deal with disaster a half mm away at all times. Lastly the rear headliner section usually needs to be trimmed to fit as well. Ignore what the experts say. Take the excess off the front edge and not the rear with the screw cutouts. IMHO the repop liners are all poorly made and shipped. My first one broke in half after a week of gentile flexing. Being tightly rolled saves shipping but renders the product very difficult to work with.
Bio acclimate or die
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I just installed a new windshield and new headliner in my 53 and these cardboard headliners are a real pain. The worst part I had was the trim above the doors and getting the cardboard fit behind it. The cardboard will crack easily and I ruined mine in one place pretty bad. That and the new cardboard is not prepunched for the sunvisors. And the metal strip that runs across the cab over the seat ended up slightly kinked and the paint chipped.
1953 GMC 1-Ton Pickup with 350 and 700R4
