1 members (Steelonsteel), 141 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
#1219777 06/02/2017 6:50 PM
52 Chevy 3600. No horn just the cap. So I want to get back to a working horn. Researched and reviewed all the posts and figure I need the spring contact bushing, the inner horn contact plate and probably the upper steering column bearing to insure the ground wire is attached. Living here in Florida near NPD, I was able to view their bearing for a 47-59 model. Just as I expected it to look except it is 1-3/4" OD. My ID of the steering column is 1-3/8" so it ain't gonna fit! Didn't even check the shaft hole diameter but the shaft OD is 3/4" and just for reference the OD of the steering column is 1-3/4". Any one with experience with this issue or know what the correct upper bearing part number would be?
I'm a tad confused. You have a 1952 Chevy. You handled a bearing that is correct for a 47-59 Chevy yet does not fit your column. Confused as how we can give you anything but the number for the bearing you've already seen.
I guess the first question is...what vehicle and year did your column come from?
I guess that's my dilemma. Nothing I have found indicates if the column has been changed. The engine was changed out to a 235. all by PO with no records. Obviously if there is only one style bearing for the 47-59, then the column must have been changed. I just cant imagine why. I guess I need someone to verify the Outside Diameter of their column.
Perhaps if you could supply some decent images someone may be able to tell what steering box you have. Finding parts for "mix-n-match" vehicles can sometimes be a challenge.
Lots more pictures
I was able to find a casting number on the gearbox 270280. It is listed in the Chevy parts manual as a gear assy. for a 1-1/2 ton. It has a p/n of 270927. Searching on the net, buyautoparts.com lists a 270280 as a gear box for a 3/4 ton. I will call them on Monday to see what more they can tell me. This does look like my gearbox and column.
http://shop.buyautoparts.com/search?view=grid&w=270280
It looks like the 47-53 1 ton through 1.5 ton steering gear assembly is the same.
COMM, 1/2 ton-1.5 ton, except non-pickup/standard-cab bodies
