| | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I replaced the master cylinder on my 58 step van and the brake pedal only goes down only slightly. The last cylinder was dead and I had no brakes, so I'm unsure of correct brake pedal travel. The brake light switch is now unable to trip because of the short travel of the pedal. should I adjust the bracket that places the switch in the pedals path? Maybe too much fluid? I sure would appreciate any comments or suggestions. Thanks, Chaz
1958 Chevy Grumman Olson step van
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Before you replaced the MC did the truck roll and stop? Are any of the wheel cylinders frozen up? Mike B | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Did you adjust the rod that pushes the MC piston so the pressure in the brake lines can release as the pedal hits the stop? After a few brake applications you might be getting a solid stack of fluid from the master cylinder to the wheel cylinders, the pedal will be very high, and all the brakes will drag. Jerry
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Thanks guys, I'll take a second look tomoorow.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Hey Jerry, I think your deduction is the most plausable. I found the return spring was worn out and now have a new one installed. The pedal is very high, and brake only goes down maybe a couple inches. How can I reduce the stack of fluid? Bleed? Thank you, Chaz
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | First, adjust the master cylinder pushrod so it takes about 3/4" to 1" of pedal travel before the M/C piston starts to move. To get the pressure off the system, crack any one of the bleeder screws open at one of the wheels and you'll probably get a quick squirt of fluid. John's fire truck was doing the same thing at the Homecoming, and shortening the pushrod a little solved the problem. Good luck! Jerry
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Shouldn't simply adjusting the push rod to the correct length allow the piston in the master cylinder to return to the fully released position, exposing the port allowing the fluid to return to the reservoir?
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Yes, theoretically. If there's more than one problem, like a collapsed flex hose, for instance, it might be necessary to vent a wheel cylinder. The problem will come back even with the right M/C stroke if that happens but only one or two brakes will drag. Jerry
| | | | | Joined: Feb 2010 Posts: 86 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 86 | does the new master cylinder have the same bore as the old one? If the new one has a larger bore it will move more brake fluid per stroke. just thinkin | | |
