6 members (MRMEROTH11, cmayna, David Bush, Hanks custodian, walter74, 1 invisible), 53 guests, and 3 robots.
Topics128,056
Posts1,055,800
Hi
I am dropping in a 283 in the Viking.
But want to still use the foot starter and the ingnition key as it is.
Anyone who has a good solution for that ?
/Ulf
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
You can fake it with a switch mounted to the floor in the same location as the original start pedal to energize the starter solenoid. There was a tech tip, or maybe just a thread on the subject some time ago. A heavy-duty starter switch from a farm tractor was used, with an extension bolt and the original pedal cap to make the conversion. Pretty tricky! There's no way to adapt a real stomp starter to a V8.
I posted some pics on that for the '48 2 ton, ( maybe 2 yrs ago?)still working fine.
One update - using the original pedal mounting stud made the pedal so high that it was easy to get too much sideways force.
Cut the end off and rethreaded so the pedai is an inch above the cap.
[email protected]
Also:
No, more like this:
https://www.amazon.com/R3682-Tracto...=8-1&keywords=farmall+starter+switch
The switch bolts to the floor, and a cap is fabricated with a short bolt welded to it to slip over the push button with the original stomp starter button screwed onto it. If you can find an original accordion-shaped rubber dust boot to cover it up, it looks almost original.
Looks like both you guys were typing at the same time! grin
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
I have a couple of old Volvo tractors. Look at this one, a T24.
The starter button in front of the ebrake handle smile smile
http://i185.photobucket.com/albums/x264/uffeg/20130420_184948_zpsxc8rwvfu.jpg
[email protected]
Also:
That looks like one ones in the above posts. It looks like it should work for what you want to do.
Rich
1947 Loadmaster
