4 members (Hanks custodian, Ponchogl, Wayne67vert, 1 invisible), 175 guests, and 3 robots.
Topics128,089
Posts1,056,139
Members48,435
#1219166 05/29/2017 6:08 PM
Whille driving the truck for the first time the other day I noticed that the realease bearing is making noise. I have to pull the drive shaft to replace a differential seal, so I guess I will drop the transmission too and go into the clutch. My questions are, should I replace the whole clutch assembly while I am there? I would presume it is the original clutch, though it seems to work fine. And should I replace the clutch pilot bearing? Is it doable without any special tools?
Thanks, Lee.
1956 Chevy 3200, 235 w/3 speed
My personal rule is......... if I'm going to tear into something I'm going to replace everything in there while I'm at it. Goes double for these old trucks.🛠
It can be done without any special tools with the exception of a clutch alignment tool, but one will be included with your clutch kit.
If you have the SM420 four speed, it is harder to wrestle out of the way than a three speed.
Others might disagree, but unless you are having trouble with the pilot bushing, I'd leave it alone if you are changing the clutch working under the truck. It is not an easy task done laying on your back. Much easier to replace when the engine is out of the truck.
Matt
Thanks for the information, I have three on the tree and will be doing all this while on my back.
If you do decide to take the pilot bushing out, the easiest way I've found is to use a 5/8" coarse thread tap. Find an 8-point socket (3/8?) and run it in. It will take less than a minute to get it out. I've seen guys pack the cavity full of bearing grease and a rod or bolt to beat the snot out of it to remove one, but the tap works easy and quickly every time.
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida' that she's cherry.
Crusing in the Passing Lane
I agree to replace or at least check(requires clutch r&r) pilot bushing or bearing.
Ed
Thanks for the info, I was a little late seeing redline's post before I found a utube video where bread was used to push the bushing out. It worked quite well, but not as easily as the tap probably would have. Not much room to swing a hammer under the truck, but it really did not take a lot of force to push it out. New clutch is in and transmission is back installed too. Thanks to all for your help.
