4 members (JW51, rfs56trk, Cosmo, 1 invisible),
119
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I recently saw a post where someone used a short saw horse (24") with a piece of plywood stretching from there to the cab floor for under the dash access. I suppose for skinny folks. I don't see how this works as the door does not open wide enough. Anyone ever try this? Steve | | | | | Joined: Mar 2009 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 62 | yep regularly,but I use a couple of 2x8's or 2x6's, whatever fits and some foam padding | | | | | Joined: Sep 2013 Posts: 1,362 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,362 | Years ago I started using a 2x12 that's about 4' long for underdash work. One end sits on a work bench stool, the other lays in the truck floor. Every thing sits at an angle to the truck. I HIGHLY recommend it. A possible disclaimer; I'm 6' at about 165-170 depending on the week, so not a big guy at all.
Ron
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, works like a charm.
What width did you use, Steve?
The right plank allows you to hold the swear words in reserve. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I have a 1 X 12 for this job and my air compressor is the perfect height to support the end of it. An added bonus is that it becomes a massage table when the compressor comes on.
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Take the seat out and use a piece of 3/4" plywood two feet wide as an under-dash access point, propped up by something the height of the door sill.
Set an alarm clock- - - -it's comfortable enough you might end up taking an unplanned nap. Jerry
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I did this little trick when I rewired the truck Jerry. You're right I almost dozed off a couple times. I like the out the door idea too so I don't have to remove the seat all the time. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Tim I found a scrap piece of ply and ripped it to about 14" and set the outside on two stacked milk crates. Perfect height. It's only 1/2", but I'm not too heavy. This is starting to sound like the Greasy Spoon. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | You have the best idea Carl. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Carl is a very creative thinker.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | I'm thinking about steel plate 1/2" thick cut to 14" wide. I'm 6-4 and 270 pounds.
Anyone have a picture of their ideas? | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | I'm thinking about steel plate 1/2" thick cut to 14" wide. I'm 6-4 and 270 pounds. A foot length of that stuff would weigh nearly 24 lb. Way too heavy to avoid slipping when putting it in place and dinging the truck. A 2x10 will hold an amazing amount of weight on the flat. I've used an 8 foot length as a bridge for a wheelbarrow full of dirt. Me and the wheelbarrow probably weigh 500 lb. A foot length of 2x10 weighs just under 3 lb, and a 2x12 is still under 4 lb/foot. That and wood is a lot softer when you bang it against the paint.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I believe that Tom is a self-deprecating leg puller. (At least I hope so, because he is very large and I am very small.)
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | I believe that Tom is a self-deprecating leg puller. (At least I hope so, because he is very large and I am very small.) I guess I'll consider my leg pulled, then.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I may be trying out this idea myself. I need to change out the wiper motor in my other truck, and not looking forward to getting under that dash. I don't bend as well as I used to either. | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Yep - humor and self deprecation. No worries! I'm away from home again on another assignment. Typically I gain weight during these assignments. I may be up to 300 pounds by tomorrow and now thinking about a steel I beam to lay on. Have a great weekend. Tom
