8 members (55shaker, classicfins, 37 GC, Otto Skorzeny, Shaffer's1950, 1946chevytruck, CandoBrent, 1 invisible),
80
Mod | | | Forums66 Topics128,128 Posts1,056,661 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 57 | My '61 C20 is a daily driver. Blew (and I mean blew, one ball was cracked in half) a front wheel outer bearing when I ventured out an hour from home. Must have hit 40 plus websites looking for a National B47. Parent company (Federal Mogul) literally waiting for a ship to dock from Asia. The inner race bore is a really odd size (.9065") for any kind of interchange or even a swap to a roller bearing. Has anybody been through this, and what was your solution? Ray Virginia Beach 61 C20 (8 lug wheels) | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Anybody with a lathe and about three brain cells to rub together should be able to adapt a bearing with a slightly larger inside diameter to the spindle. Just machine a sleeve with a flange on it for the spindle nut to tighten against that will center the bearing on the spindle. A first-year machinist's apprentice would be able to turn out something as simple as that in a matter of minutes. Jerry
| | | | | Joined: Apr 2005 Posts: 2,099 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,099 | GM didn't reinvent the wheel when they built that truck. It's possible it uses the same hub/drum as a later model. I believe they went to Timken type bearings in 63. Have your parts store look up the later application. You also might even be able to find a used hub with bearings for a 63-66 at a wrecking yard. Fred
| | | | | Joined: May 2018 Posts: 1 Moderated | | Moderated Joined: May 2018 Posts: 1 | Hello, I am curious how you you solved your bearing problem as I have the same issue with mr 1962 C40 using the same B47 bearing. | | | | | Joined: Nov 2008 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 57 | OMG. First I tried the route(s) Fred suggested. Where I live we don't have much ancient iron, but I called around anyway. No go. Also my local Napa insisted it didn't match anything else so I was kind of stumped. What worked was googling the original GM part number and seeing what popped up. An antique Buick parts dealer had one on the shelf for $70 or so. I snatched it and had in by the end of that week. National Bearings had some inbound on a ship from China at the time, but declined to sell me one right off the boat--and said it would be months before O'Reilly and the other parts stores had it. I think the one that failed was a Chinese copy because the ball holder thingy was some sort of plastic. The OEM is definitely metal. | | |
