| | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I had a little time to replace the exhaust gasket and fix a leak this past weekend so I decided it would be a good time to install an offenhauser manifold that was given to me along with a Holly 390 cfm 4 bbl carb. It was all going well until I found that the two studs that connect the exhaust manifold to the intake manifold were about 1/2" too long and interfered with the intake manifold. I found very quickly that vice grips were not going to remove the studs without help from a torch. It seems that the easiest solution would be to run a die down the studs to get more threads and use a cut-off wheel to remove the extra 1/2". I'm reluctant to do this because the studs will now be too short for the stock intake if I run into a problem and need to change back. Is this a common problem when making this change? Is there a better solution to solve the stud length? Thanks for any suggestions.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | It seems like your saying that the studs have an unthread section up against the manifold. This is common when the stud has two different thread pitches. If so, I would think you would remove the offending studs and replace with the correct length and pitch that mates to the manifold. Nuts to match the thread pitch would be no problem and who is going to know. I would try to remove the old studs with two nuts (jam nut) and use "Kroil" oil and be real slow by working the stud back and forth. Sheared manifold studs can make grown men weep.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Don't forget to use brass nut, also.
Ed
| | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | I used heat on the two studs and removed them without to much problem. It was easy to get heat on them due to the locations. I now use standard bolts the correct length. | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 |
Larry
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Not Ed, but answer is corrosion. I prefer silicone bronze myself, but that's just me.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Steel nuts ' weld' themselves to the studs, frequently making them impossible to get off, especially with restricted access. Brass has enough different expansion than steel, so that never happens.
Beltfed, where is a good source for Si-bronze nuts?
Ed
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I purchase from "McMaster-Carr" (404) 346-7000. Internet also. Example: 5/16-18 hex nut, p/n 93435A032 is around $15.00 plus shipping, several years ago, for bag of 100.
Larry
