| | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | Has anyone used this (Rust Bullet), or ever heard of someone using it.Is it a superior product or just a flash in the pan.
"you can't fix stupid"
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have used it, as a test I put it on straight over a heavily rusted bumper & tossed it out in the yard-has been there over a year & half now(holding water sometimes),,so far it has not rusted again,even where it is stiing on the ground,,brian | | | | | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | I have used it too and I say to buy it and you will see it is a great product. They say to put 2 coats on very important. I used it on the outside mirrow braces. and did most of the outside of the cab. Sanded lighty just to get the flakey stuff off and put 2 coats on criss cross pattern with a 2" brush. You have to clean the brush over and over if you want to use it the next time. It goes on silver and in the sun it will turn a gold color.
1951 1.5 ton 4400 | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I buy the cheap bags of brushes @ Wally world & toss them after use, also if you get it on you you gotta wear it a while,I use latex gloves,,it also never comes out of clothes, brian | | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | thatnx for the thoughts.fleetside, that bumper still out being used as a birdbath?
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Well, I just turned it over while I was weedeating around the shop, it still looks good-it takes up too much space to store inside. Brian | | | | | Joined: Apr 2005 Posts: 1 Moderated | | Moderated Joined: Apr 2005 Posts: 1 | I too have used it, successfully, definitely get some brushes to throw away and me being a lady I would advise wearing protection and clothing you don't care about. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Is this a product that should not be sprayed on with a gun? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Lonnie, it says not to thin,,but I sprayed it into windshield posts & door hinge pillars using an air suction gun, was messy but worked. Brian | | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | again thanks for all the info
