4 members (walter74, baldeagle, BillCollins, Cosmo), 75 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#121895 09/06/2006 4:23 AM
Has anyone used this (Rust Bullet), or ever heard of someone using it.Is it a superior product or just a flash in the pan.
"you can't fix stupid"
#121896 09/06/2006 1:49 PM
I have used it, as a test I put it on straight over a heavily rusted bumper & tossed it out in the yard-has been there over a year & half now(holding water sometimes),,so far it has not rusted again,even where it is stiing on the ground,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#121897 09/08/2006 4:01 AM
I have used it too and I say to buy it and you will see it is a great product. They say to put 2 coats on very important. I used it on the outside mirrow braces. and did most of the outside of the cab. Sanded lighty just to get the flakey stuff off and put 2 coats on criss cross pattern with a 2" brush. You have to clean the brush over and over if you want to use it the next time. It goes on silver and in the sun it will turn a gold color.
1951 1.5 ton 4400
#121898 09/08/2006 1:17 PM
I buy the cheap bags of brushes @ Wally world & toss them after use, also if you get it on you you gotta wear it a while,I use latex gloves,,it also never comes out of clothes, brian
#121899 09/10/2006 4:35 AM
thatnx for the thoughts.fleetside, that bumper still out being used as a birdbath? grin
#121900 09/19/2006 6:42 PM
Well, I just turned it over while I was weedeating around the shop, it still looks good-it takes up too much space to store inside. Brian
#121901 09/19/2006 7:44 PM
Moderated
Moderated
I too have used it, successfully, definitely get some brushes to throw away and me being a lady I would advise wearing protection and clothing you don't care about.
#121902 09/19/2006 9:35 PM
Is this a product that should not be sprayed on with a gun?
#121903 09/20/2006 2:09 AM
Lonnie, it says not to thin,,but I sprayed it into windshield posts & door hinge pillars using an air suction gun, was messy but worked. Brian
#121904 09/20/2006 4:34 AM
again thanks for all the info
