1 members (ronsway), 185 guests, and 2 robots.
Topics128,167
Posts1,057,019
Members48,458
So I glued down some bubble insulation on my firewall/floors using 3M 77. I got some over-spray on my kicks, which have an acrylic clear over top. Now parts of them are rough to the touch. Can anyone suggest a way to remove this? Or can I put a clear back over-top to try and smooth it out? It's not show quality, but trying to do what I can to make it presentable.
Thanks!
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
I've used WD-40 or mineral spirits to remove the glue and not effect the paint. 3M also makes an adhesive remover, but it could remove the paint if the paint has not cured for at least 90 days.
Tim
1970 VW Beetle
Thanks Tim, I'm going to try that this weekend. Fingers crossed...
More images
You might try Prep-Sol or similar paint cleaner, it's more of a solvent than mineral spirits but won't attack the paint.
Perhaps a light TSP?
More images
Z
Z Offline
How about using a clay bar ????
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
Goo Gone! It's a mild adhesive remover. Rinse with water immediately after removing the glue to neutralize the Goo Gone.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
