0 members (),
87
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 728 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 728 | So I glued down some bubble insulation on my firewall/floors using 3M 77. I got some over-spray on my kicks, which have an acrylic clear over top. Now parts of them are rough to the touch. Can anyone suggest a way to remove this? Or can I put a clear back over-top to try and smooth it out? It's not show quality, but trying to do what I can to make it presentable.
Thanks! | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | I've used WD-40 or mineral spirits to remove the glue and not effect the paint. 3M also makes an adhesive remover, but it could remove the paint if the paint has not cured for at least 90 days.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Jan 2016 Posts: 728 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 728 | Thanks Tim, I'm going to try that this weekend. Fingers crossed... | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | You might try Prep-Sol or similar paint cleaner, it's more of a solvent than mineral spirits but won't attack the paint. | | | | | Joined: Jan 2016 Posts: 728 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 728 | | | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | How about using a clay bar ????
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
| | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | Goo Gone! It's a mild adhesive remover. Rinse with water immediately after removing the glue to neutralize the Goo Gone. | | |
