| | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2017 Posts: 3 New Guy | | New Guy Joined: May 2017 Posts: 3 | I have a 1953 1/2 ton that I purchased . It currently has a Chevy 10 bolt rear end under it. On the drivers side the caliper is on the rear side and on the passenger side the caliper is in the forward position. Is this normal or is there a reason they are not both on the same side? It has gm mid size calipers with parking brake option and both are marked L for left side? Truck was restored many years ago. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | To start, your truck was not "restored" if it has rear disc brakes, it was modified.
As for the calipers being on opposite sides, My F-250 came that way so I have no doubt many GM vehicles did too. | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Bntolong, Believe you have the same system that I used. It's bade by The Harrison Road CO. Now I'm using their brakes on a 3/4 ton. But if you find the instructions you might become enlightened. Because the Calipers are mounted the same as yours.
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Feb 2000 Posts: 5,233 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,233 | Late 70's and early 80's Firebirds, and Camaro's had off set calipers like you describe. They could use only one caliper for both sides, saved money that way. I believe the Cadillac's used the same caliper in those years. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | My Gen-3 Borg Warner rear end came like that,it caused some issues hooking the parking brakes up,a Lokar kit cured that but since i've changed out my rear suspension for a parallel 4 link,the LH caliper parking brake mechanism fouls the axle mount.
I have noticed the ones with the alloy calipers are both in the same orientation to each other.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2017 Posts: 3 New Guy | | New Guy Joined: May 2017 Posts: 3 | Appreciate all the info. I have since found out the rear end came off the seventies Camaro | | | | | Joined: May 2017 Posts: 3 New Guy | | New Guy Joined: May 2017 Posts: 3 | | | |
