| | | Forums66 Topics128,175 Posts1,057,053 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It appears to me you are looking for pictures of heavily modified trucks. I moved you to the HiPo shop. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Your links aren't working? Photobucket can be a troublesome site.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Jan 2013 Posts: 2,237 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,237 | Gnarly,
Take a look at mine. It is all original, however, I had front axle bent 4 inches and rear end dropped 3 inches using blocks. Front axle is about 4.5 inches off the ground. I have a hard time using trailers. All shocks and leaf springs are original. I have a ruler laying by the front axle. In the picture I am not level with camera and you can still see the 2 x4 under both tires.
Chris
| | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Just be sure that you have everything above the "scrub line".
You should be able to have the truck roll with either front tire removed from the rim, without anything dragging on the ground.
Also, you'll need to have your steering arms corrected for the drop- especially for the drag link angle.
You can find examples of trucks on Nostalgia Sid's website: droppedaxles.com
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Jan 2013 Posts: 2,237 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,237 | I used Sid at dropped axles. Like Dave stated, ensure you have it all planned out and calculate your scrub line more than once. I screwed it up and went lower then I should have.
Chris | | |
