| | | Forums66 Topics128,014 Posts1,055,325 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | I have a '47 3100. No wing windows. I was cleaning, painting, and repairing my door channel and door mechanism. When I unscrewed the window frame from the riser bar I found there were two connections at both ends of the window frame that connect the top and bottom pieces of the frame. One connector was missing and the other has some sort of A counter sunk "rivet" that was just loosely inserted into the Connection. Doesnt appear correct. Don't think a simple nut and bolt is the answer as they would catch and wear on the window channel. My question is, "What have others done to connect these two pieces together?" I'm sure this has been addressed before. I'm looking for some cures. Thanks. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | What is a riser bar? Is this an Advance Design '47?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | I'll try re-phrasing and use better terms. The riser bar rides on the regulator arms . The "bar" then is screwed to the bottom of the frame. The frame has an upper A's well as a lower section that surrounds the glass. It's the actual type of connector that I'm inquiring about. I think it's time I spend time learning to post a picture. Someone told me, "a picture is worth a 1000 word". I'm a slow learner........ | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | OK, I've got the "picture" now. Those tiny fasteners are not rivets. They are a countersunk nut and bolt affair with clutch heads on them. Classicparts.com carries them.
| | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | Gee thanks 52Carl! I had no idea what the heck actually filled those two holes. Someone removed those some time ago and simply jammed in a screw head into only one opening. Gives new meaning to "Jerry-rigging". Hehe Thanks again for the help. | | |
