2 members (WICruiser, tclederman), 41 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#1218113 05/21/2017 6:27 PM
I have a '47 3100. No wing windows. I was cleaning, painting, and repairing my door channel and door mechanism. When I unscrewed the window frame from the riser bar I found there were two connections at both ends of the window frame that connect the top and bottom pieces of the frame. One connector was missing and the other has some sort of
A counter sunk "rivet" that was just loosely inserted into the Connection. Doesnt appear correct.
Don't think a simple nut and bolt is the answer as they would catch and wear on the window channel.
My question is, "What have others done to connect these two pieces together?"
I'm sure this has been addressed before. I'm looking for some cures.
Thanks.
What is a riser bar? Is this an Advance Design '47?
I'll try re-phrasing and use better terms. The riser bar rides on the regulator arms . The "bar" then is screwed to the bottom of the frame. The frame has an upper A's well as a lower section that surrounds the glass.
It's the actual type of connector that I'm inquiring about.
I think it's time I spend time learning to post a picture. Someone told me, "a picture is worth a 1000 word". I'm a slow learner........
OK, I've got the "picture" now.
Those tiny fasteners are not rivets. They are a countersunk nut and bolt affair with clutch heads on them. Classicparts.com carries them.
Gee thanks 52Carl! I had no idea what the heck actually filled those two holes. Someone removed those some time ago and simply jammed in a screw head into only one opening. Gives new meaning to "Jerry-rigging". Hehe
Thanks again for the help.
