5 members (dt235sd, Hush, Rich'sToys, Toadwart, 1 invisible), 296 guests, and 3 robots.
Topics128,087
Posts1,055,999
Members48,430
#1217901 05/19/2017 10:45 PM
A friend installed a 700R4 transmission in a 1964 GMC short bed 1/2 ton pickup in his shop. He gave me the 3 speed that was removed from the truck. I'm trying to figure out what it is. It is not a SM318 unit but what seems to be a more heavy duty 3 speed. It is a short, top loader (6 bolts) with a rear flange that bolts to the output shaft like an SM420 and used a driveshaft with a slip joint. It has a casting number on the side of the case C-94981.
I did some research on a GMC site and it lists a Warner T89B
and a New Process 746G as options.
None of the pictures of the Warner look anything like this thing and was unable to find anything on the New Process.
I would appreciate any information on this unit.
Fred
rfs56trk #1218018 05/20/2017 10:25 PM
The New Process is a 4 speed. The BW T89 is not a top loader. What you describe sounds like a BW T86 out of a Jeep.
rfs56trk #1218022 05/20/2017 10:43 PM
Thanks, I got the info that I posted from 6066 GMC Guy on the net.
It has the standard GM trans to bellhousiing bolt patterm.
I have looked at numerous pictures of 3 speed transmissions and nothing snows up.
Fred
