| | | Forums66 Topics128,050 Posts1,055,760 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | A friend installed a 700R4 transmission in a 1964 GMC short bed 1/2 ton pickup in his shop. He gave me the 3 speed that was removed from the truck. I'm trying to figure out what it is. It is not a SM318 unit but what seems to be a more heavy duty 3 speed. It is a short, top loader (6 bolts) with a rear flange that bolts to the output shaft like an SM420 and used a driveshaft with a slip joint. It has a casting number on the side of the case C-94981. I did some research on a GMC site and it lists a Warner T89B and a New Process 746G as options. None of the pictures of the Warner look anything like this thing and was unable to find anything on the New Process. I would appreciate any information on this unit. Fred
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The New Process is a 4 speed. The BW T89 is not a top loader. What you describe sounds like a BW T86 out of a Jeep. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Thanks, I got the info that I posted from 6066 GMC Guy on the net. It has the standard GM trans to bellhousiing bolt patterm. I have looked at numerous pictures of 3 speed transmissions and nothing snows up. Fred
