5 members (artinva, Opelika Tom, JW51, Gdads51, Otto Skorzeny), 65 guests, and 2 robots.
Topics128,077
Posts1,055,932
Members48,430
These came out of a lot box. Appeared important so I did not throw away. Anyone help me id?
GENUINE SUSPENSION SEMA 9-1. Tapered bolt.
http://s1377.photobucket.com/user/douglashamilton1/library/fan%20shroud/lowering%20bracket
~ HB
1962 Chevrolet C10
1962 Suburban
I believe those are intended to fit between a spindle and a lower ball joint, and they should work on any IFS vehicle with the right taper to the ball joint stud. Something similar would be needed to space the upper ball joint to maintain something close to correct suspension geometry. There would still be issues with the tie rod angles and possible bump steer.
One seemingly minor change in the way a suspension system was engineered and manufactured usually results in several unintended consequences, but hotrodders have always been smarter than the guys who make a living designing this stuff- - - - -am I right?
am I right?
He's sitting back in his comfy easy chair, peeling out line, waiting for for someone to pick up the bait.
Don't fall for it greenhorn, its a trap!
We lose too many of the young ones that way. smile
What does one call these things.
~ HB
1962 Chevrolet C10
1962 Suburban
When I was in procurement with the DOD, things like that were referred to as "widgets".
Fred
Widgets. I should have known that.
~ HB
1962 Chevrolet C10
1962 Suburban
"P.T. Barnum Specials"
eeeek
I think i will use them as c clamps.
~ HB
1962 Chevrolet C10
1962 Suburban
Those may not be for lowering. I have seen and worked with similar parts, and they do go in just as Jerry posted. However, they go on the upper balljoint and spindle, rather than the lower, and are used for lifting 4x4 pickups. They're usually installed along with dropped crossmembers for the lower control arms/torsion bars, plus dropped pitman and idler arms to correct the steering geometry. They allow the upper control arms to be kept in the stock location, which usually also incorporates the camber/caster adjustments.
Bill Burmeister
Thanks for more info. Keep trying to throw these away but i know they are exactly what someone is looking for. I just dont know how to look to find that someone.
~ HB
1962 Chevrolet C10
1962 Suburban
Sounds like a good item to have on hand at the next swap meet to me!
I will put them with the 235 block, which is nicely stored in John's barn.
~ HB
1962 Chevrolet C10
1962 Suburban
Sounds like a winner to me! Thanks!
62401
Don't encourage him, Jerry.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Moderator
Moderator
2 Offline
In the Tool and Die world.
Those are die clamps.
Suspension part?
No way!
Don't ask me how I know.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Had not thought thru that angle.
~ HB
1962 Chevrolet C10
1962 Suburban
I did some research, those are balljoint spacers for a '55-'57 Chevrolet Passenger car.
Discussion on the HAMB about these.
Bill Burmeister
