| | | Forums66 Topics128,050 Posts1,055,704 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 14 Junior Member | | Junior Member Joined: Mar 2006 Posts: 14 | This may be a dumb question but I'm painting some engine parts with Hi-temp paint. The ? is do I prime these parts? If so is there a Hi-temp primer I neeed to use?
Thanks! | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | High temp rattle can paint is self priming, but you do want to wire brush the rust off and bake out any oil before you coat it.
The only spot on a stovebolt engine that actually needs high temperature paint is the exhaust manifold, the rest of it stays cool enough that standard paint is fine.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2006 Posts: 14 Junior Member | | Junior Member Joined: Mar 2006 Posts: 14 | Thank You. As usual I over thought it! | | |
