5 members (Tronman, Phak1, 32Fordpuchoptop, Ponchogl, k2handyman), 88 guests, and 2 robots.
Topics128,042
Posts1,055,520
Members48,424
#121743 08/20/2006 9:21 PM
Junior Member
Junior Member
This may be a dumb question but I'm painting some engine parts with Hi-temp paint. The ? is do I prime these parts? If so is there a Hi-temp primer I neeed to use?
Thanks!
#121744 08/21/2006 7:17 PM
High temp rattle can paint is self priming, but you do want to wire brush the rust off and bake out any oil before you coat it.
The only spot on a stovebolt engine that actually needs high temperature paint is the exhaust manifold, the rest of it stays cool enough that standard paint is fine.
Paint & Body Shop moderator
#121745 08/21/2006 7:19 PM
Junior Member
Junior Member
Thank You. As usual I over thought it!
