2 members (papas52, carbking), 69 guests, and 1 robot.
Topics128,115
Posts1,056,292
Members48,439
#1216797 05/11/2017 3:08 AM
I've had my '53 3100 for over two years & have never had this problem. I filled the tank a couple of days ago. Tonight I noticed gas leaking from the fuel cap. I removed the cap and the tank "burped" and the fuel receded. I left the cap off, checked it later and the fuel level was back at the level of the cap. I started it up & the fuel level dropped again. What's going on?
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
I've had mine expand and overflow if it was filled all the way to the top and it was a really warm day. Most of the time I don't put that much in it so it's not a problem. I'd suggest not filling it quite so full next time.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
It sounds like expansion due to warm temps and over filling. I suggest next fillup, when the nozzle shuts off the first time, don't add more. Or fill until the guage reads full or just under and stop.
1959 3100 Apache Fleetside
I've done the same. If you're going to fill it up to the tip top you need to drive 5-15 miles before parking for the day. Also or try to park with the filler on high side if possible.
•1952 Chevrolet 3800 pickup
---All pictures---
Ex Hall Monitor
Ex Hall Monitor
An additional thought. If your tank "burped" when you removed the cap, the cap vent may be plugged.
Depending on the cap.
Most new caps allow air to enter but build a little pressure if the fuel expands, they're not freely vented like the old/original caps were.
---All pictures---
Grigg makes a good point.
Many of the off the shelf "vented" caps comply with the EPA standards to reduce gasoline vapor. They have a one way valve that lets air in as the gas level goes down but don't let anything out. I've seen huge pressure buildups in some tanks.
I remove the spring from the valve if I can't find an old style cap.
And yes, don't fill the tank above the bottom of the filler neck unless you are going to burn off a couple gallons before stopping.
I listen to the filler neck when I'm filling. As soon as I hear a unique gurgling sound that I've gotten use to which to me is when the tank get's close to full, but before the gas starts hiking up the filler neck. That's when I stop.
Craig
Ex Hall Monitor
Ex Hall Monitor
Interesting. I wasn't aware that the new caps had a one way vent. I guess today wasn't a total waste. grin
Thanks for the comments, everyone. I think it's the gas cap as the weather here in Ohio was in the 50's all day so it probably wasn't due to heat expansion. It burped again when I opened the cap so I'll look into that issue.
~Denny
1953 Chevy 3100
That sounds like an annoying issue. I never fill my truck more than about 3/4 of a tank because of similar issues. Luckily for me she is a toy and not a daily driver. That being said, if I am going to go cruising I can fill her up all the way because I know that she will burn off the top part of the tank anyhow.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
The new cap I recently purchased had a one-way plastic valve in it, and I drilled a 1/4" hole through the plastic. No more rediculous tank pressure.
This excess pressure can't be good on the float needle/seat in the carburetor.
