| | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | I've had my '53 3100 for over two years & have never had this problem. I filled the tank a couple of days ago. Tonight I noticed gas leaking from the fuel cap. I removed the cap and the tank "burped" and the fuel receded. I left the cap off, checked it later and the fuel level was back at the level of the cap. I started it up & the fuel level dropped again. What's going on?
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I've had mine expand and overflow if it was filled all the way to the top and it was a really warm day. Most of the time I don't put that much in it so it's not a problem. I'd suggest not filling it quite so full next time. | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | It sounds like expansion due to warm temps and over filling. I suggest next fillup, when the nozzle shuts off the first time, don't add more. Or fill until the guage reads full or just under and stop.
1959 3100 Apache Fleetside
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've done the same. If you're going to fill it up to the tip top you need to drive 5-15 miles before parking for the day. Also or try to park with the filler on high side if possible. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | An additional thought. If your tank "burped" when you removed the cap, the cap vent may be plugged.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Depending on the cap. Most new caps allow air to enter but build a little pressure if the fuel expands, they're not freely vented like the old/original caps were. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Grigg makes a good point. Many of the off the shelf "vented" caps comply with the EPA standards to reduce gasoline vapor. They have a one way valve that lets air in as the gas level goes down but don't let anything out. I've seen huge pressure buildups in some tanks. I remove the spring from the valve if I can't find an old style cap. And yes, don't fill the tank above the bottom of the filler neck unless you are going to burn off a couple gallons before stopping. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I listen to the filler neck when I'm filling. As soon as I hear a unique gurgling sound that I've gotten use to which to me is when the tank get's close to full, but before the gas starts hiking up the filler neck. That's when I stop.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Interesting. I wasn't aware that the new caps had a one way vent. I guess today wasn't a total waste.
| | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | Thanks for the comments, everyone. I think it's the gas cap as the weather here in Ohio was in the 50's all day so it probably wasn't due to heat expansion. It burped again when I opened the cap so I'll look into that issue.
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | That sounds like an annoying issue. I never fill my truck more than about 3/4 of a tank because of similar issues. Luckily for me she is a toy and not a daily driver. That being said, if I am going to go cruising I can fill her up all the way because I know that she will burn off the top part of the tank anyhow.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | The new cap I recently purchased had a one-way plastic valve in it, and I drilled a 1/4" hole through the plastic. No more rediculous tank pressure. This excess pressure can't be good on the float needle/seat in the carburetor.
