2 members (LAROKE, Gray_Ghost), 124 guests, and 1 robot.
Topics128,105
Posts1,056,543
Members48,448
#1216567 05/09/2017 4:49 AM
Z
Z Offline
Just recently purchased after many years of searching for it a 1948 chevy 6400 open cab fire engine 235ci, 4 speed with 2 speed rear the truck served over 35 years as line duty engine but now has been sitting since the 90s what are some things i need to look for before trying to fire her up aside from cleaning gas tank and running new fuel line and carb rebuild
also what brand 6v batteries do yall prefer and where are yall sourcing brake parts.
Zach
Welcome to Stovebolt.com, Quintrell864
Optima 6v battery.
I got most of the parts for my 54/55 GMC 2-ton from Rockauto.com (often by using aftermarket part numbers from people here). They are "lean" on big truck parts, though.
Welcome!
Hope someday you can post some pictures of your truck.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Welcome fellow firebolter!! As for parts I'll let those much closer to you comment. For work first done, you've got fuel covered, check through ignition to be sure all good too.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
Welcome to the Stovebolt wave
I'd also like to see pictures, I'm working on a '56 4400 Open Cab NAPCO 4x6 Brush Truck.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Crusing in the Passing Lane
Since you are in the rust belt, oil the valve stems, make sure all the valves go down easily, so no pushrods get bent.
I have a '37 GMC open cab fire truck, nice driver, yours looks nice, good you have it covered.
Ed
Z
Z Offline
awesome thanks for the advice and welcoming. let me know if you have problems with this photo link i checked it in preview and it worked for me
photobuckett
Zach
Cool truck! I want it.👋🏻🛠🚒🚒🚒🚒🚒🚒🚒🚒
Wow! Love it, so cool. Good luck with it, take your time - it will be worth it.
