| | | Forums66 Topics128,163 Posts1,056,918 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 5 New Guy | | New Guy Joined: Dec 2015 Posts: 5 | I'm giving up on my lever shocks- I'm missing the link arms, and one is frozen up.
Based on my measurements one ton brackets are totally different size than the small half tons, due to the bigger springs, correct? I see people sell kits on ebay with everything, but I don't think they'll work. I have both a 1/2 ton front axle and my 1 ton to compare.
I need left & right lower shock mount brackets for TUBULAR shocks. I have a '49 3800 with bad lever shocks and would like to install tubes.
Anyone know of a source? I've tried calling carters, and I've now posted a wanted ad here. Are 4100 and 4400 the same sizes? (but probably not too common)
I don't really want to resort to my fab skillz, or paying the local fab / weld shop.
| | | | | Joined: Dec 2015 Posts: 5 New Guy | | New Guy Joined: Dec 2015 Posts: 5 | Also, the brackets for the lever type that I have are flat, not angled. I don't think they'll bend- they look to be a casting of some sort.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | You may be able to use something like this. It's for a 55-59 truck. The 55-59 used 2" springs like the early 3800. POL bracket | | | | | Joined: Apr 2016 Posts: 102 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 102 | Check out Ecklerstrucks.com search part # 61-247541-1. I put them on my 48 3600, so far so good. I put in new ubolts for mounting also. I have found it is easier to torch old suspension bolts then fight them.
Jon | | |
