3 members (55shaker, JW51, Gdads51), 147 guests, and 1 robot.
Topics128,069
Posts1,055,896
Members48,428
#121637 08/14/2006 11:36 AM
You may recall a previous post where I had bought a 'hydraulic lifter' 235 to replace the 'solid lifter' 235 in my 57 TF. I thought the engine was from a 57 Belair but found out later (check those numbers BEFORE you spend money) that it was a 62 engine.
I thought you may be interested in knowing the problems I've ran into so far:
1. Front motor mounts didn't work. 62 motor didn't have the taps on the side of the block to fit the 57 mounts. I had to drill the cross-member and mount under the front plate like the pre-55's did. No big deal to change.
2. I got a big surprise yesterday when I tried to attach my gas pedal linkage. The post that holds the swivel piece is located about 3" toward the rear on the 62 motor. I had to shorten the linkage from the pedal to the swivel piece and re-arc the curve through the floor. Minor annoyance if you have a welder.
I'll keep you posted on any other difference. (Why didn't I just drop that darned 283 in there.)
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
Since this is more of a driveline thing, I'm going to move it to engine and driveline, but thanks for the update!
I had to do similar things when I put the 261 in my truck. It's worth it, though.
Paint & Body Shop moderator
