| | | Forums66 Topics128,050 Posts1,055,673 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | You may recall a previous post where I had bought a 'hydraulic lifter' 235 to replace the 'solid lifter' 235 in my 57 TF. I thought the engine was from a 57 Belair but found out later (check those numbers BEFORE you spend money) that it was a 62 engine.
I thought you may be interested in knowing the problems I've ran into so far:
1. Front motor mounts didn't work. 62 motor didn't have the taps on the side of the block to fit the 57 mounts. I had to drill the cross-member and mount under the front plate like the pre-55's did. No big deal to change.
2. I got a big surprise yesterday when I tried to attach my gas pedal linkage. The post that holds the swivel piece is located about 3" toward the rear on the 62 motor. I had to shorten the linkage from the pedal to the swivel piece and re-arc the curve through the floor. Minor annoyance if you have a welder.
I'll keep you posted on any other difference. (Why didn't I just drop that darned 283 in there.) | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Since this is more of a driveline thing, I'm going to move it to engine and driveline, but thanks for the update!
I had to do similar things when I put the 261 in my truck. It's worth it, though.
