8 members (Wayne67vert, TUTS 59, Hotrod Lincoln, Otto Skorzeny, klhansen, Shaffer's1950, Dragracefan, fonz8261), 172 guests, and 2 robots.
Topics128,165
Posts1,056,992
Members48,458
Saw it done years ago during my 3.55 installation (by a seasoned old car mechanic). Ran a piece of brown paper bag through the ring and pinion to check how things meshed. Must've been good, because I've got many thousands of reliable miles on that diff. Anyone know the details on that procedure? Is it the magic thickness for proper backlash or something?
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
H Online: Content
A $25.00 magnetic base dial indicator from Ebay or Harbor Freight Tools is a much better and more accurate way to check gear backlash. I usually try to get to .010"-.015" if possible. The tooth contact pattern, checked with white lead paste or Prussian Blue is at least as important as backlash, maybe more so.
ODSS Lawman
ODSS Lawman
I agree with both of Jerry's comments. Not sure what the bag can do other than make a mess. Gear lash is important but a central gear contact pattern even more important.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Any idea why the manual recommends such a tight spec at .005-.008? Even Patrick's old instructions say no tighter than .008-.012.
Matthew 6:33
H Online: Content
New gears in the 40's and 50's had a habit of "wearing in" a little, so the factory setup took that into account. Newer production items probably have the benefit of a little more accurate manufacturing, plus better heat-treating, so they can be set up to the tolerances the gears ended up with after a run-in period.
I know my grandfather talked about doing it this way with newspaper(20s, 30s and 40s). Old timers could set the lash by reviewing the prints on the newspaper.
1946 Chevrolet 1/2-ton
More pix on Photobucket
