| | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I did a good cleaning and lubricated my wiper motor and sealed it with RTV. It works very well now except when the switch is in park there is a leak, wipers park properly but leaks until I move the switch back just slightly. I have had it apart 2 times and cannot see the cause any one run into this before?
Jackie | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I disassembled, cleaned, and applied a thin coat of white lithium grease in the tub and on the edge of the paddle. It is working well but has a vacuum leak when wipers are in park. | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | The switch parts are wear-prone. You are fortunate that you can fiddle with it to make it stop hissing.
