4 members (dt235sd, Rich'sToys, wilbur53, Stovebolt48), 173 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
#1215906 05/03/2017 11:33 PM
I did a good cleaning and lubricated my wiper motor and sealed it with RTV. It works very well now except when the switch is in park there is a leak, wipers park properly but leaks until I move the switch back just slightly. I have had it apart 2 times and cannot see the cause any one run into this before?
Jackie
JackieC #1215918 05/04/2017 12:45 AM
Where did lubricate the wiper "motor"?
Here are the correct lubrication points - light oil
I disassembled, cleaned, and applied a thin coat of white lithium grease in the tub and on the edge of the paddle. It is working well but has a vacuum leak when wipers are in park.
The switch parts are wear-prone. You are fortunate that you can fiddle with it to make it stop hissing.
Moderated by  ndkid275, Phak1
