6 members (Shade Baby, Otto Skorzeny, Dennys28, Mike B, klhansen, 1 invisible), 82 guests, and 2 robots.
Topics128,120
Posts1,056,649
Members48,450
49 GMC 1/2 ton is in the garage. So cool I can't wait to get into the build. Lots of questions to come. First one
I want to keep the straight axle and add P/S. I've read a number of posts that were very negative on the R/P set up, but the posts were from years ago. Was wondering if there are any updates ... pro and con. Who has done it and the outcomes. I see kits for with and without R/P.
The rack must be mounted to the front axle to prevent bump steer which means a slip joint is required in the steering shaft--not desirable. There is a unit called "Uni-Steer" that just uses one rod out of the frame mounted rack in a cross steer fashion like 48 and older Fords had. Cuts down on bump deflection but still not perfect. Many have used the early to mid 80's Toyota pickup p/s boxes mounted in place of the factory box with good results but the popularity has pushed the price up. Before you go exotic I'd get everything brought up to like new specs and drive as is (probably runs about a grand). If you like the old time way it rides, handles, drives, the air noise, and the sounds and smells of an old truck then your good to correct what short comings you feel it needs rather than spend a bundle and then decide it's not for you.
Evan
Electric power steering while retaining the original steering box is the way to go with a straight axle.
Thanks for the quick replys. Think I'm going to like this forum.
I bought the truck in pieces so it's not drivable now and likely won't be until next spring /summer. It's from New Mexico and was tore down in 1998 then put in storage. The only parts assembled are the frame, EVERYTHING else was loose or in boxes. They were going to go SB Chevy and had crossmembers for engine and tranny made. The sheet metal was sanded down to bare metal. No drive train came with. Pretty much starting from scratch. Was planning on mounting on a S-10 frame but changed my mind and will use the existing frame. (By the way I now have a 87 S-10, 4-wheel dive, regular cab, long box for sale with a new long block 2.8)
I'll post pics soon.
Tom
I have been told R/P and leaf springs are a death trap. I just ordered an EPAS electric P/S from jegs for $1500. Watch the video on the jegs site and see what you think. My thoughts are it's a 53 it should have leaf springs. Properly set up they work quite well.
