3 members (Tom McGrath, Wheelie, Jimmie D), 97 guests, and 2 robots.
Topics128,195
Posts1,057,374
Members48,469
#1215795 05/03/2017 1:13 AM
New clutch, finally fired off truck. Clutch won't release. Any ideas. Just grinds and wont go into any gear.
What did you take out to install the new clutch? Did you remove the stick shift and top plate of the tranny? New pressure plate and throwout bearing? We need more info
Riding in the Passing Lane
You might have the disc in backwards. The pilot shaft may be tight in the pilot brg.
1972 Chevy c10 Cheyenne Super
Yes new pressure plate pilot bearing throw out bearing. Yes had top plate off and shifter out. All went back together no problems.
Crusing in the Passing Lane
There are short and long throwout bearings, long is 1.875".
Ed
If you did not get the shifter fork from the stick back correctly that could cause shifting problems. Also the throw-out bearing length as mentioned.
with engine off, will shift through gears no problem. with engine off, in gear, push in clutch and cant move vehicle. will check length of throwout bearing.
appears to have long throwout bearing.
Well, turns out to be rookie mistake. Disk was in backwards. Oh well, on to the next problem.
Chalk another one up for Wrenchbender Ret.🛠
