Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Peggy M, lumbersawyer, baldeagle, frogfarmer, Hotrod Lincoln), 29 guests, and 1 robot.
Topics128,005
Posts1,055,260
Members48,418
#1215710 05/02/2017 12:32 PM
O.K. got a 235 out of a 1958 chevy car 3 speed, I found a 216 out of a 1951 chevy car 3 speed, can I use this engine and use the parts off the 216 bell housing, flywheel front motor mount, etc,and install in a 49 3100. I've read the tech tip many times just need a yes or no...Thanks
Ted Skidmore #1215737 05/02/2017 3:42 PM
3B Offline
Hy Ted Skidmore, No. While I am no car of that era expert, the car engine bellhousings I have seen have no mount provisions on them, also the mounting pattern for the car transmission is different/smaller than that of the truck, hope that helps.
Ted Skidmore #1215747 05/02/2017 4:51 PM
There is most likely some helpful information posted in your earlier 4 posts.
"O.K. got a 235 out of a 1958 chevy car 3 speed, I found a 216 out of a 1951 chevy car 3 speed, can I use this engine . . " Which engine - the 216?
- Yes, the 216 could be used in a 1949 3100 - direct bolt in (all parts - except maybe you will need a truck clutch housing).
- If you are referring to using the 58 235 car engine - is should also bolt into the 1949 3100, but you should relocate the water pump on the block (and us a truck clutch housing).
Will your truck be 6v or 12v?
- Use the clutch-assembly and flywheel and starter for the appropriate "voltage". The teeth on the flywheel are different for different voltages.
