0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 20 | well here's my 64 4x4 I bought this about 4 yrs ago it's a 64 sittin on a 72 4x4 running gear it had a 307with 4 spd and 3/4 ton diff's with 4:56's, I changed them out to 1/2 3:73's more road friendly then I swapped out the 307 to a 292, now it has a BBC 402 still have the 4spd..Iv'e did a lot of work which you can see in the pictures and still need to do some things..not sure if the link will work... I thought I submitted this when I first got it nut never saw it in the gallery... randycox http://s1168.photobucket.com/user/randycox1/library/
| | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | sounds like you have done a lot of work, however, your link does not work. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | It does now. At least it did for me. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | | | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 |
1961 apache
