1 members (Peggy M), 74 guests, and 0 robots.
Topics128,094
Posts1,056,064
Members48,433
#1215407 04/30/2017 9:57 PM
My 1950 speedometer does not work. The needle moves when turning the cable by hand but not when attached to the transmission. I used a bore camera through the hole for the driven gear and now know why it doesn't work, no drive gear.
I can't tell if the long spacer is there either. I have an old transmission I tore down to inspect for rebuild. It has the drive gear but no rear spacer (#17) . I have searched but have not found any of these available. I am using a Garmin right now to stay honest but would like to have the original speedometer working.
Jackie
JackieC #1215411 04/30/2017 11:08 PM
H Online: Content
I've got a couple of those transmissions- - - -let me check to see if it's got what you need. It looks like it would be very simple to make one if necessary.
Awesome....thanks Jerry!
Jackie
It seems this part is specific to the 1948-1954 Chevrolet Trucks with the 3-speed transmissions.
I am in need of part #17 in the picture HERE . Or dimensions for it so I can have one made. I have 2 transmissions neither one have this part. I want to rebuild the spare so it includes a functional speedometer.
Jackie
The parts book says 1" I.D. X 3.54" long.
My Blog
I know I asked this question 5 years ago and do appreciate the responses, At the time I asked the transmission was working very well and I didn't want to remove it just for the
speedometer. Well I have the transmission removed because #9 in this diagram has busted and I have no second or third gear. Since I have the trans torn down I thought I would make the speedometer functional.
What would be the best material to make this part from?
Thanks.
Jackie
I finally made the spacer for the speedometer gear. I used a piece of 1 inch I.D. aluminum schedule 40 pipe cut just a touch over 3 1/2 inches long (3-17/32 or so).
Speedometer works now!
