2 members (Johnnydog, 78buckshot), 60 guests, and 2 robots.
Topics128,060
Posts1,055,832
#1214952 04/27/2017 2:30 PM
I
I Offline
I'm having some issues with my 41. First, is has a couple breaks between the vertical bars, I guess they are just from stress over the years as it is the original grill. Do I need to get those welded up or are they ok as long ase the grill is secured?
Second, there are some places in seccurring my grill missing screws. I put some screws in but they vibrated out not long after. Is there a certain type of screw to use or a better way to fix this?
Stovebolter -- the Next Generation
(I'm 20)
1941 Chevy 1/2-ton pickup
"Lucy"
More pix on Photobucket
1967 Ford Mustang - "Sally"
For the screws, you can either use Threadlocker or shake proof washers. I'd lean towards the shake proofs.
Not knowing how extensive or where the breaks are in the grill bars, might steel splints held in place with epoxy be an option? My thought would be to use 6 penny or larger size nails and JB Weld on the backside of the grill. Some sort of clamping jig might be needed to hold the grill pices in place while the epoxy cures.
DLBrooks
DLBrooks
Are the breaks at the bottom of the grill and maybe some of the mounting points? And I take it is a painted grill?
If at the bottom of the verticals, I would remove the grill- sanblast - and place a 1/4 or 3/16 inch bare steel rod inside the entire bottom bending the rod to the contour as I did on my 42. MIG tack in place on bottom/back side rejoining any seperated pieces. Weld other breaks as necessary.
1959 GMC 100 Fleet
Follow in the DITY
