| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I was out at the mecum auction in Houston a couple weeks ago, and an old collector was selling about 50 cars out of his collection. I noticed many of the older ones had isolation (ball) valves on the heater hoses both to/from. Sounds like a good idea for autos that mostly sit. How would you drain the core without draining the hole system? Maybe they just close the inlet and outlet valves and unhook the hose on the outlet side and drain into a bucket without draining the whole system. Would that work?
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I'll venture a swag. Inorder for the heater core to stay constantly hot, coolant must flow in and out. Which would seem to indicate one feed could be a suction side. Or at least a return to the pump. By shutting off the pressure or "in" side to the core 1st, The suction or "out" feed "may" draw coolant out before its closed. What they are probably doing is keeping both sides closed keeping the core bone dry and never using the heater.
I dunno, just a swag. | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | If you stop the flow in either hose it will keep the coolant from circulating but there will still be fluid in the heater core. Stopping it on the pump side might slightly reduce the pressure in the heater but unless you have converted to a pressurized cooling system it shouldn't really matter. I added a simple cable operated valve in my truck so I could regulate the flow from the cab. http://i99.photobucket.com/albums/l286/Hookalatch/Heater/IMG_1752.jpg | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 |
